SOME PICS MIGHT HELP!
YOU MENTIONED STEALERSHIP, ARE YOU ABLE TO PERFORM EZ TESTS?
ARE YOU INSTALLING THE STARTER?
THIS IS WHAT I FOUND TO BE "STOCK" ENGINES FOR A '86 MUSTANG
2.3L 4 CYL
2.3L TURBO
3.8L V-6
5.OL V-8
I RECKON I SHOULDA THREW THIS IN BEFORE.......HAVE YOU MESSED WITH THE SPARK PLUG WIRES?.......MAYBE AN EVIL BUDDY DID WHEN YOU WEREN'T PAYING ATTENTION???
IT COULD BE POSSIBLE THAT THE THEY ARE INSTALLED WRONG. WHEN I WAS IN HIGH SCHOOL, IT WAS A GOOD [EVIL] JOKE WE WOULD DO TO EACH OTHER, IT GOT TO THE POINT WHERE WE WOULD RIG A LOCK ONTO OUR HOOD TO PREVENT IT
IF YOU "JUMPED TIME", THIS MIGHT CAUSE IT
IF THE DISTRIBUTOR GOT LOOSE/ OR INTENTIONALLY MOVED, THIS MIGHT CAUSE IT
ELABORATE ON ANYTHING I MENTIONED
BEFORE YOU/ THEY MESS WITH 'EM MORE, MAYBE WITH YOUR ENGINE SIZE (IF IT'S STOCK) I CAN HELP YOU SEE IF THEY ARE IN THE CORRECT SEQUENCE ON THE DISTRIBUTOR CAP AND ON THE SPARK PLUGS
YOUR TURN
THE MEDIC
May 13, 2013 at 7:35 PM
