Starter will not engage the flywheel
2002 SATURN L200
150,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
TRISTON C. G. THACKER
  • 8 POSTS
My car shut off on the way to work. I replaced the alternator, tested the battery, both are good now. My starter for some reason will not engage the flywheel. I had it tested at AutoZone and they said it was good. I put it back on with a fully charged battery and it still just spins. Please help, any ideas are appreciated.
Jan 19, 2018 at 1:13 AM
Good morning.
Are you saying the starter motor turns but does not turn the motor?
if it does, two possibilities:
1. Bendix drive bad in starter.
2. Flywheel damaged on the motor.
Jan 19, 2018 at 3:38 AM
  • 8 POSTS
Flywheel is good, but if the Bendix is bad would it pass an AutoZone test?
Jan 19, 2018 at 2:46 PM
Sure, the starter would turn fine but would not engage the flywheel.
Jan 19, 2018 at 2:53 PM
  • 8 POSTS
I will replace the starter, I will get back to you if it fixes the problem. Worst case scenario at least i will get a refund and the old one back if it does not work.
Jan 19, 2018 at 9:00 PM
Keep us updated and thank you for visiting 2CarPros.
Jan 21, 2018 at 5:15 AM
  • 8 POSTS
I rebuilt the starter but it still does the exact same thing. Is it possible the ignition switch is bad?
Jan 31, 2018 at 10:01 AM
did you replace the bendix drive at the end of the shaft???
no, you have power and it turns
Jan 31, 2018 at 10:40 AM
  • 8 POSTS
Replaced the starter. The engine will turn but won't crank. I am getting spark. All fuses are fine.
Feb 3, 2018 at 3:36 PM
the engine will turn but will not crank?? if the engine is turning, it is cranking. Please explain
Feb 4, 2018 at 5:32 AM
  • 8 POSTS
the engine will turn but it will not start. I turn the key to the start position and everything moves, it just wont start.
Feb 4, 2018 at 10:20 AM
ok, thanks.
did you check for spark and fuel?? that is the next step.
Feb 4, 2018 at 7:06 PM
  • 8 POSTS
Checked all 4 pins on the coil pack, I have spark. Took the plugs out and they smelled like gas and the fuel pump kicks on.
Feb 4, 2018 at 8:12 PM
OK, so you have spark at the plugs??
you need to check the actual fuel pressure to be sure it is putting out the proper pressure.
Feb 5, 2018 at 3:16 AM
