My battery drains overnight. It used to be more sporadic but now it's every night. Pulled all the fuses in the vehicle to find the parasitic drain, no change in reading. Tested the alternator output while running and under electrical strain-looks good. Battery is new. With the vehicle off and key out of the ignition, I tested with the multi-meter against the metal body of the starter solenoid and the disconnected negative terminal of the battery-about 12 volts. Would the short be in the starter solenoid, cabling or ignition switch?
Mar 17, 2019 at 5:15 AM
