Starter and flywheel are grinding
1999 FORD EXPLORER
170,000 MILES • V6 • 4WD • AUTOMATIC
LUIS3
The starter was installed about 11 months ago it was new not a rebuild. I went to start the car and it just grinds. It didn't crank over just a grind. I tightened up the starter thinking it may have come lose, and no change. Any advice? Please help! I can't afford a shop to look at it right now.
Mar 2, 2016 at 12:16 PM
JDL
  • 16,098 POSTS
I'd have to visually check your starter and flywheel, see if the flywheel has any missing or badly worn teeth. If it is problem with bad flywheel teeth, sometimes you can rotate the flywheel to get the bad spot away from starter, then it will crank normally. Of course that doesn't fix the problem. Check the starter drive gear, is it badly worn? Some makes and models, you can use shims at the starter to get starter and flywheel teeth, to mesh properly. My biggest problem is I can't see anything from here.
Mar 2, 2016 at 12:33 PM
MHPAUTOS
  • 31,937 POSTS
The old starter may have worn the teeth down on the ring gear and now the new starter is starting to slip, remove the starter and inspect the teeth on the ring gear first.
LUIS3
Thanks a lot for the advice. I'll pull the starter out and check it out.
Mar 2, 2016 at 1:29 PM
