Starter
2001 TOYOTA SEQUOIA
255,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
MARCH7
  • 6 POSTS
The trouble I am having is that I am not getting the starter to turn over. it has power to it and it works. it is not the relay switch and the motor is not locked up and neither is the flywheel. it appears that the electrical signal is not strong enough to turn the starter motor. Any suggestion?
Feb 22, 2017 at 3:45 PM
CJ MEDEVAC
  • 11,004 POSTS
An auto parts store might verify if the battery is up to par.
Check out my link below.
https://www.2carpros.com/questions/1996-chevrolet-tahoe-wont-start-sounds-dead-battery-jumpbox-get-same-reults
Return with good news!
The Medic
Feb 22, 2017 at 4:00 PM
MARCH7
  • 6 POSTS
We bypassed the battery with a battery charger that has a start option ran it direct.
Feb 22, 2017 at 4:08 PM
CJ MEDEVAC
  • 11,004 POSTS
Results?
The Medic
Feb 22, 2017 at 4:20 PM
MARCH7
  • 6 POSTS
Was not able to get the starter to operate the way it should. I know the starter works had it tested and is new also the starter relay is new.
Feb 22, 2017 at 4:23 PM
CJ MEDEVAC
  • 11,004 POSTS
Did you look over my long boring link with pictures?
No clicking or slight starter movement?
That puppy got a security system that might keep you shut down?
Give me every description of your vehicle they gave it (like SE, SLT, ETC.) or give me the VIN number might take me straight to a correct starting diagram in "Prodemand". I will post it for you/maybe give other suggestions.
Your Turn,
The Medic
Feb 22, 2017 at 4:34 PM
MARCH7
  • 6 POSTS
Will have to look that up and get back with this information. thanks
Feb 22, 2017 at 4:45 PM
MARCH7
  • 6 POSTS
Here is the VIN number.
5TDZT34A51S018074
Feb 22, 2017 at 5:02 PM
CJ MEDEVAC
  • 11,004 POSTS
I am Baaaaaack!
I got one diagram
I had to make three screenshots to get it all (Prodemand will not just let you copy it, as they are a 'pay' manual)
So anyway at the bottom they look like one chunk, there are three pieces.
The first is the top, second is middle, third is bottom. I made sure that they overlap so nothing is missing, some is repeated.
You could print these and tape them together if you want to.
You have a neutral safety in there, some fuses, a fusible link. Things commonly that fail.
Prodemand gives the names, numbers and locations to find the items in the diagram.
I am no salesman, but, our site also has a way to buy rent the entire manual for most modern vehicles. If you surf or perform a search at the top of the page you should be able to find them. If not, let me know, I locate them for you.
Keep us posted
The Medic
Feb 22, 2017 at 6:31 PM
MARCH7
  • 6 POSTS
Thank you for the information. Will look for this and get back with you. Marc
Feb 23, 2017 at 4:40 AM
