Hey Mastied,
Here are the instruction you needed
Disconnect negative battery cable. Remove air cleaner outlet tube and air cleaner assembly. Drain engine cooling system. Disconnect the 3 hoses and position thermostat aside. Remove starter solenoid cable nuts and position solenoid cables aside. See Fig 8 . Remove starter motor mounting bolts and starter motor. See Fig 9 . To install, reverse removal procedure. Tighten bolts to specification. See TORQUE SPECIFICATIONS
Here is a guide that will show you what you are in for
Please let us know happens so it will help others.
Here are start motor diagrams for what it will be like for your car (below) both engines.
Best, Ken
May 23, 2020 at 11:02 AM
(Merged)
