Where is the starter located?
1993 CHRYSLER FIFTH AVENUE
78,000 MILES • 3.8L • 6 CYL
KELLYLUCK
Where is the starter?
Nov 2, 2022 at 12:35 PM
The starter is under the car, on the right side, and is located where the engine and transmission meet together. It will be partially under the exhaust manifold.
There are two wires you need to remove after you remove the battery cable. Then there are two 5/8 bolts that secure it to the transmission.
Before you begin working on it, make sure to disconnect the battery first.
Let me know if you have questions.
Nov 2, 2022 at 2:59 PM
