Well, do you have the receipt from the work and any tests that were done before?
See if there is a starter draw test, a battery load test and/or even a mention of charging the battery.
Any short circuit can drain the battery overnight. The overhead light would have to be intermittently on while it is supposed to be off though in order to drain the battery. It is possible though that it is coming on intermittently because of the intermittently function that you did notice, using the ammeter would show you what is going on and when.
Apr 19, 2018 at 7:25 AM
