Started to run rough
2006 CADILLAC CTS
92,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
GUSTAVO CUELLO
When in idle is very rough, started smoking black.
Jul 9, 2018 at 1:54 PM
Based on your description, it sounds like the engine is getting too much fuel. There are several things which can cause this. Also, black smoke is usually the result of a very rich fuel mixture.
The first thing I would recommend checking is the fuel pump pressure and the fuel pressure regulator. Here is a link that will walk you through the process:
Lets start with that test first. I have attached a picture of what the fuel pressure should be.
Jul 11, 2018 at 8:10 PM
