This morning the engine ran rough, missing, blowing black smoke; running rich. Engine light is on but no one (not even a Ford dealer) can read the ODBII port. (It use to work until about a year ago.) So something is wrong.
I replaced the O2 sensor and it still ran rough. I disconnected the battery to let the ECU reset. Started and it ran fine. Turned the engine off, let it set for an hour, then started again. Ran rough, black smoke, etc. Disconnected battery again, started and ran fine. Turned engine off for a few seconds and restarted. Ran rough for maybe five seconds then smoothed out.
This is strange behavior to me. Given this and the ODBII port not working (a mechanic traced continuity and power from the port to the ECU), I’m suspecting the ECU is the problem and was ready to order a replacement. Then I read an answer here that said the ECU is almost never the problem.
One other item. The docs I find says my E350 has 3 O2 sensors. Left/right upstream and one downstream. I only find one a foot or so ahead of the catalytic converter. If I’m missing some those could need to be replaced.
Any suggestions on the richness problem or the missing O2 sensors?
Apr 16, 2019 at 5:23 PM
