Car listed above is not supercharge.
Have replaced fuel pump and filter. thermostat housing and coolant temperature sensor along with cam shaft sensor.
Have spark
Turns over but would start in not using starting fluid down intake snorkel.
Cold compression
90
85
90
90
no oil added for test.
took apart throttle body no much carbon and clean it with throttle body cleaner along with MAF.
Originally had over heating issue but think have that licked.
Did see there was an ambient air sensor but use bore scope for plastic intake nothing cracked.
will check for codes tomorrow.
Thank you.
Have spark
Cold compression
90
85
90
90
Thank you.
Dec 22, 2020 at 6:26 PM
