What you described sounds like a poor connection. It could be at the battery, the starter, or a fuse/relay.
I attached the wiring schematic below for the starting system for your reference. I'm not sure if it has a smart key or not, so I went with "not". If that's wrong, let me know.
Now, since everything is new, are you certain the engine isn't locked up, preventing the starter from turning it? If you have checked and it turns, we need to next confirm all connections are tight, clean, and free of corrosion. Although the battery is new, please confirm it is fully charged and the connections to it are clean and tight.
Take a look through this link. It describes exactly what you described and what to check for.
Next, I attached the wiring schematic below and highlighted fuses and relays to check. As far as the click you hear, is it in the vehicle or under the hood? There are two different relays related to the starting system and they are at different locations.
When you check the fuses identified, first, confirm the fuse itself is good. I suspect you already did that. However, if the fuse is good, you should also confirm there is power to and from it. Here is a link you may find helpful:
Next, if all fuses are good, confirm both relays are good. If there is a different relay with the same part number in the box, switch them to see if it makes a difference. If there isn't, here is a link that explains how to test one:
See pics below. Note: I had to cut the schematic in half to make it readable for you. I did overlap the two pics so you can follow from one to the next. Also, I attached pics of the fuse boxes and fuse locations.
Jan 10, 2022 at 8:41 PM
