Starting issues
1981 MERCEDES BENZ 240D
200,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
KOLOTOUR
Here's the story: Attempt to start the car. Turn key and everything powers up. Headlights are bright. Buzzers working. Turn key to engage starter and get one click and then nothing. And I mean nothing! Everything is dead. No headlights, no dash lights, nothing. Battery is clean and fine. 13.5 V. Fuses are fine. Wait 4 or 5 minutes and everything is back on line. Headlights, etc. are all working again. Try to start again and one click and everything off!! Have done this 4 times. I'm thinking that something is sticking and slowly releasing. Maybe the solenoid? I don't think a starter relay would act like this. Does the starting process disconnect everything electrical momentarily and restore power when the engine starts and the solenoid disconnects ?
Dec 16, 2019 at 11:55 AM
It sounds like you have either a loose or corroded battery terminal (or both). Take a look through this link and let me know if it helps:
Dec 16, 2019 at 2:53 PM
KOLOTOUR
Joe,
Good call. The battery posts and connectors were very clean, but the negative battery connector was an after market item that clamped to the cable. I took that apart, cleaned it and the bare copper wires from the cable and bingo we have ignition!! In my past experience if you get the click it's a dead battery. It doesn't come back to life in 4 minutes. But the article you sent explaining the heating and cooling process was very helpful. Now I can file that in the overflowing part of my brain that explains how stuff works.
Dec 16, 2019 at 5:10 PM
Glad to hear you got it going. I'm starting to see that kind of a problem more and more. One click, everything goes dead, and then shortly after, power returns. LOL
Take care and let us know if you have questions in the future.
Have a great Holiday,
Dec 16, 2019 at 5:18 PM
