B2991 Right front door ajar circuit malfunction, C0050 Right rear wheel speed sensor circuit malfunction, P0121 Throttle/pedal position sensor/switch "A" circuit range/performance. Plus the ABS and The stabilitrac service light comes on randomly too, even just sitting idling. I changed the pedal position sensor and the right rear wheel speed sensor and erase the codes but in a few days they come back, it does seem to be more prominent in wet weather, do you suspect the PCM? I inspected wiring and connections and all looks good.
Nov 7, 2018 at 12:25 PM
