Starting problem
2016 VOLKSWAGEN CC
57,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
ROLAND SHULI
Hello, i start the car in morning without any problem, i drive it for thirty or forty minutes i park the car then i go back after fifteen to twenty minutes it always happen second time it does cranking sound like engine stalling and i try again it starts normally.
Feb 2, 2019 at 4:44 PM
It sounds like a fuel pressure issue. What I want you to try is this. After driving and under the conditions it would normally act up, try this.
1) Turn the key to the run position (not start / Engine off) and count to five.
2) Turn the key off and repeat step 1 a total of three times.
3) See if it starts normally.
If it does, it is a fuel pressure related issue. Let me know the results.
Feb 2, 2019 at 10:51 PM
