My SUV started stalling while driving it a couple months ago. It had a check engine light that said mass air flow sensor. We replaced it. It did not fix it. It kept popping up different codes so we replaced the crank positioning sensor, fuel cap, ignition switch, fuel pump relay, ECM, replaced ground wires and mass air flow sensor as before mentioned. The fuel pump has been tested twice and the battery has been tested. Nothing is correcting the problem. We have had no engine lights since replacing the ECM. It does restart after it shuts off, but sometimes it will take a few minutes. It will run a little way then shuts off again. When it is driving it runs perfectly. Any thoughts would be appreciated.
Aug 21, 2017 at 10:07 AM
