Hard start
2005 CHRYSLER 300
200,345 MILES • 3.5L • V6 • 4WD • AUTOMATIC
MARIAS300
  • 5 POSTS
When i star my car sometimes it will start first try if i'm lucky. if not i have to do all kinds of things until it starts. i bought already a new battery, new set of keys. can it be my alternator?
Aug 12, 2021 at 12:44 PM
SQM
  • 6,383 POSTS
From what you are describing, it does not sound like a bad alternator. If your alternator was bad then after you start it the car will not stay running for very long. It will stall.
So the issue you are having is that is it does not start the first try you will have to try over and over before it starts?
The time it does not start, what does the engine do? Does it crank? Does is make any clicking noise?
Please let me know little more details.
It sounds like the issue could be a faulty starter or an ignition switch.
https://www.2carpros.com/articles/how-a-starter-and-solenoid-works
It can even be the crankshaft position sensor. A faulty crank sensor can trigger intermittent starting issue.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Please let me know what you are observing.
Thank you.
Aug 12, 2021 at 1:23 PM
MARIAS300
  • 5 POSTS
2 rwd is my car not a 4wd i made a mistake. so will that make a difference on my car problem?
Aug 12, 2021 at 1:40 PM
SQM
  • 6,383 POSTS
It will not make a difference if it's a rear wheel drive or all wheel drive, with the issue your are describing.
If you would let me know little more details of the issue that you are experiencing (as from my response above). Thanks.
Aug 12, 2021 at 1:43 PM
MARIAS300
  • 5 POSTS
so my car when it turns on it stays on until i turn it off. It has power it runs like a champ. the only thing is the starting issue it turns and a click sound is all i hear.
Aug 12, 2021 at 1:44 PM
MARIAS300
  • 5 POSTS
it does not turn over it just clicks.
Aug 12, 2021 at 1:45 PM
SQM
  • 6,383 POSTS
So all the gauges and dash lights come on as usual. But when you turn the key it just clicks, right?
The clicking sound can be either the starter relay or the starter.
First check the starter relay. The relay is located under the hood in the main fuse box (see diagram below).
Pull out the relay and do a visual inspection. See if there is any burnt pin or corrosion on the connector.
You can also test the relay as well.
Here is a guide on how to do that:
Next item needs to be checked is the starter. Many times the starter will have this type of intermittent issue when the main wire that goes from the battery to the starter is loose or has corroded terminal. With a corroded terminal the power from the battery does not got to the starter as it should and it will just click. Then as you are trying to start it for few more time it can all of a sudden get enough power to crank the engine and start.
Please let me know what you find.
Thank you.
Aug 12, 2021 at 2:57 PM
MARIAS300
  • 5 POSTS
Okay, so I decided to take my car to AutoZone since they check the battery etc. well, results was my alternator is bad. I don't know, but that is what they diagnose my car.
Aug 13, 2021 at 2:23 AM
SQM
  • 6,383 POSTS
Interestingly the alternator does typically does not impact the starting in a manner that you are experiencing. If the alternator is bad then your car can just stall and when that happens you will not be able to start it back up. You might be able to jump start it but it will stall again. Also a bad alternator will drain your battery, and it will have the battery light illuminated on the dash.
Aug 13, 2021 at 6:53 AM
