If it is the tcc, it should shall immediately, if that is the problem. Can you check for trouble codes? to check codes, you use a jumper between terminals A & B at the data link connector, under lower edge of dash, probably between the steering column and driver door. With jumper connected, turn key just till dash lites come on, no further, then the mil on the dash starts flashing, you count the flashes to get the codes, your looking for two digit codes. An example, a code 23 would be 2 quick flashes, slight pause then three quick flashes. It may repeat three times before moving to next code.
I'd probably want to give it a tune-up. See if that helps, check all filters, check fuel pressure.
Feb 12, 2015 at 9:42 AM
