Stalls at idle?
2012 VOLKSWAGEN JETTA
100,000 MILES • 2WD • AUTOMATIC
JOAN1961
For a while, the car would rumble occasionally at idle, but nothing would come of it. Recently, it started stalling on its own when idling in a parking lot or drive thru lines. It's stalled 3 times now. When it does, the battery light comes on the dash, but the car starts up like there's no problem. Any ideas before I take it into the dealer?
Mar 29, 2023 at 7:04 PM
The most common cause is an engine vacuum leak. They can be caused by disconnected hoses, cracked or dry rotted hoses, or leaking gaskets or seals.
This is where I would start.
Here is a link that explains how to locate a leak and repair it:
Also, take a look through this link and let me know if it helps:
https://www.2carpros.com/articles/stall-at-idle
Mar 29, 2023 at 9:23 PM
JOAN1961
Thank you so much! I will check it out.
Mar 30, 2023 at 1:16 PM
You are very welcome. Let me know what you find or if I can help in any way.
Mar 30, 2023 at 7:09 PM
