Stalling out when I slow down
2007 DODGE MAGNUM
106,630 MILES • 2.7L • 6 CYL • RWD • AUTOMATIC
NASIR83
For a while my car has been stalling when I slow down or about to slow down to reach a stop light. After googling the problem, I saw that the signs that I would see seemed to be the Throttle Body. Also a mechanic who I have went to for a while also said the problem sounds like its my throttle body. Any way, when the car shuts off I put it in neutral and restart the car and I have to press the gas or it wont start back up. I really needed to have this problem fixed and sadly the mechanic that I was preparing to take the car to closed down and now I have been stuck with this problem trying to fix it my self. So I ordered a used throttle body online and changed out the old one and the same problem is still happening. Could it be that the throttle body I just recieved is having the same exact problem as my old one or could there be something else cause this issue. I am still getting the same problems as before. PLEASE HELP ME OUT ASAP!!!!
Jan 27, 2014 at 9:47 AM
I have to be honest, it doesn't sound like a problem with the throttle body. Have you checked for engine vacuum leaks? Have you checked the idle air control valve? Has the check engine light come on?
Jan 27, 2014 at 9:52 AM
