It always had a p420 code, but the car ran fine at all speeds. Added Cat Cleaner to try to clear code with no luck, but right after cleaner was added engine was started and wouldn't stay running. You had to keep pumping the gas pedal all the while keeping it at 2,000-3,000 RPMs to keep it from shutting off. The engine was cold. As the engine warmed up it would run better. When the gauge hit operating temperature (180-190?) the stalling/shutting off stopped and you could drive the car with no problems until you stopped and turned it off again and let it cool down. Then I started the car again and the symptoms returned. The shop I have the car at replaced the fuel pump and Map or MAF sensor(?) Didn't solve the problem. They don't know where to look next. Any clue what could be wrong?
Apr 20, 2023 at 4:58 PM
