Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
F-550
Engine
Symptoms
Stall While Driving
stalling and shut off?
2004 FORD F-550
34,000 MILES • 0.6L • V10 • 2WD • AUTOMATIC
HOT876RADIO
MEMBER
1 POST
FOLLOW
stalls while idle, can you help me fix it?
Mar 19, 2023 at 9:53 PM
CERTIFIED EXPERT
This can be caused by a vacuum leak, or the throttle body needs to be serviced. Also, there could be a vacuum line to the IAC motor that has fallen off. Here is a guide to help you find the leak. Please use it when the engine is cold only.
This guide can help as well:
https://www.2carpros.com/articles/stall-at-idle
Also, we should run the codes to see what comes up.
Please go over these guides and report back.
Mar 20, 2023 at 1:51 PM
