I have two digital gauges and one analog, and I can set any one of the three on the AC Volt setting and just go across the battery posts without the battery even being in the car and all three read the same, AC volts is always double what the DC volts are.
This is the first time I've ever had a car run on battery power and die when the voltage goes to 13 and above. On volts.
I wouldn't believe me either, but I saw the meters and so did my customer. one meter is the $10.00 Harbor Freight one, the analog is by Hyper tough and it's the $22.00 little box with a sweep needle, little wheel on the side to adjust and Zero the OHM meter, old school type, and the third is a INNOVA 3306A ( www.iEquus.com ) digital meter and it cost $23.00 to $30.00 bucks. I figured that a test meter set on AC volts hooked in on a DC voltage system would read Zero on the analog, and the digital meters would have a blinking bar where the numbers would be, but if AC voltage bleed through the system you'd get a reading instantly.
In 48 years of working on cars, trucks, vans ,motorcycles, gas and diesel welder / generators, and various other pieces of construction site equipment, this is the first time I've ever checked for AC voltage getting out of the alternator, but I've never had a car idle and rev up till it hits 13 volts then shuts off, you can even hear the fuel pump relay click ( releasing the power to hold the relay on for the fuel pump ) at the same time it hits 13 volts.
Is there some sort of safety feature in test meters to keep them from frying when they get hooked up that way? My oldest test meter is 11 years old. Maybe I need a $125.00 meter like you have so it doesn't do the things mine does, I don't know.
I do agree with you, I shouldn't get any reading at all on a meter set to AC volts that's hooked up to a 12-volt DC Battery, but I do, and it's always double what the DC voltage is.
Now I have to find out what is wrong with the Cabriolet and why these test meters do this voltage thing, my mind won't rest until I have the reason why they do. Got a cheaper meter? Set it on AC volts and do a reading on your car battery and see what you get, if you could please. This is going to destroy my brain, and at 64 years old, it won't take much, just kidding. Trying to keep a since of humor on this strangeness.
Thank you, and I hope you don't think I'm trying to mess with you, I'm just trying to fix an 88 VW Cabriolet. Thanks.
Dec 25, 2023 at 6:38 PM
