Random stalling
2013 FORD FUSION
64,322 MILES • 1.6L • 4 CYL • 2WD
RAYW1961
Random stalling thinking it's the fuel pressure sensor or the throttle body itself going to replace both, but cannot find the location of the throttle body.
Jan 11, 2019 at 1:35 PM
Good afternoon,
The throttle body is a common failure for this.
Before you replace it, I would try cleaning the plate of all carbon as that is the reason for stalling.
Procedure below
Throttle Body
Removal
WARNING: Before beginning any service procedure, refer to Safety Warnings in General Information. Failure to follow this instruction may result in serious personal injury. See: Vehicle > Initial Inspection and Diagnostic Overview
WARNING: Do not work on the fuel system until the pressure has been released and the engine has cooled. Fuel in the high-pressure fuel system is hot and under very high pressure. High-pressure fuel may cause cuts and contact with hot fuel may cause burns. Failure to follow these instructions may result in serious personal injury.
WARNING: Clean all fuel residue from the engine compartment. If not removed, fuel residue may ignite when the engine is returned to operation. Failure to follow this instruction may result in serious personal injury.
NOTE: Removal steps in this procedure may contain installation details.
1. Refer to: Health and Safety Precautions See: Vehicle > Technician Safety Information > Health and Safety Precautions (General Information). See: Vehicle > Initial Inspection and Diagnostic Overview
2. Refer to: Jacking and Lifting - Overview See: Vehicle Lifting > Procedures > Jacking and Lifting (Vehicle Jacking and Lifting). See: Vehicle Lifting > Procedures > Jacking and Lifting
3.
Help See: Vehicle > Components > About This Information
4.
1. Torque: 5 Nm
2. Refer to: Quick Release Coupling See: Fuel Line Coupler > Procedures > Quick Release Coupling (Fuel System - General Information).
5.
1. Torque: 5 Nm
6. NOTE: When disconnecting the Throttle Body (TB) electrical connector disengage the red locking tab on the Throttle Body (TB) electrical connector by sliding it to the rear of the Throttle Body (TB) electrical connector, away from the Throttle Body (TB). Squeeze the Throttle Body (TB) electrical connector while removing.
NOTE: When connecting the Throttle Body (TB) electrical connector engage the red connector locking tab after fully installing the Throttle Body (TB) electrical connector. The red tab will not slide forward unless the Throttle Body (TB) electrical connector is fully installed.
Torque: 10 Nm
7. NOTE: Make sure that a new Throttle Body (TB) gasket is installed.
Jan 11, 2019 at 1:59 PM
RAYW1961
This year model car has no throttle cable it's all driven electrically. I know how to do everything with cleaning throttle body and relearning the throttle position sensor with my computer diagnostic tool I just need to know where the location of the throttle body is on this particular vehicle. I followed the air hose tube are Boot and it goes from the driver side engine compartment all the way down to the passenger side on the back side of the engine. I cannot see exactly where the throttle body is located. if you could pinpoint that for me I would sure appreciate it. this car is not turbo it is just a 1.6 l EcoBoost.
Jan 11, 2019 at 4:23 PM
It is buried down on the intake manifold.
Did you remove the top cover from the motor and follow the intake tube from the air filter?
Jan 11, 2019 at 4:42 PM
RAYW1961
Yes I did. the air tube runs down to the side of the bottom of the engine not underneath it but to the side. I guess I'll put it up on the lift and see if I could see it better from the bottom. never seen one located there before but that's where the air tube ends. Thanks for all your help.
Jan 12, 2019 at 9:18 AM
You are welcome.
Always glad to help.
Jan 12, 2019 at 9:20 AM
