Engine shuts off when car has been driven more than an hour
2006 PONTIAC TORRENT
178,000 MILES • 3.4L • V6 • 4WD • AUTOMATIC
CSIGMON95
Can only be driven for an hour and a half to two hours before shuttering and shutting off. Then it won't restart unless you wait a few hours. After waiting it starts right back up and again can only be driven the same time frame before shutting off out once more.
Jun 23, 2019 at 5:58 AM
Good morning,
When it does not start, you need to test for fuel pressure and spark to see which area has the issue.
Try spraying some starter fluid into the air filter and see if it starts and stall. That will tell us if it is fuel delivery or spark.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Jun 23, 2019 at 6:12 AM
CSIGMON95
Also may be worth nothing that I've replaced all spark plugs, 3 O2 sensors, and the MAF sensor. Still having the issue.
Jun 23, 2019 at 6:14 AM
Got it.
All of them would have no effect on the issue.
Jun 23, 2019 at 6:19 AM
