Do you mean the starter spins but doesn't engage with the flywheel/engine? Is it possible for you to record it and upload it for me to see?
If what I described above is correct, the starter is bad. There is 12v from the battery direct to the starter. A smaller wire (trigger wire) provides 12v only when the key is in the start position. So, there isn't anything separate that causes the starter to engage.
Here is a link that explains how to test the starter. Take a look through it.
https://www.2carpros.com/articles/starter-not-working-repair
Now, if the engine is turning and not starting, try this. See if it will start for a couple of seconds and then stall if you use starting fluid. If it does, then we know it's a fuel-related issue. If it still doesn't even try to start, we need to recheck ignition components.
Here are three links. One explains how to check for spark to the engine, one is for checking fuel pressure, and one is general for a crank no start condition.
_________________________
Let me know what you find or if you have other questions. Honestly, if I could hear what it is doing, it would likely be very helpful.
Take care and God Bless,
Mar 11, 2021 at 7:19 PM
