stalled and will not start
2005 DODGE MAGNUM
170,000 MILES • 6 CYL • AUTOMATIC
ROLLFAMILY
Have had no problems with it starting before. Took it to a shop to check on a water leak. Left the shop drove about five miles and stalled making a left turn and now will not start. Only a few "clicks" when try to start. AAA tried to "jump" start but the same. Any suggestions?
Oct 15, 2017 at 3:40 PM
MHPAUTOS
  • 31,937 POSTS
You need to test for spark, fuel pressure and injection pulse, make sure that the engine has not seized after the over heat problem. can you turn the engine by hand? if so check that the starter is okay, the click sounds as if the starter solenoid is engaging and the starter is not turning.
Oct 16, 2017 at 4:35 AM
