Engine shut off and will not start
1999 TOYOTA CAMRY SOLARA
150,000 MILES • 2.2L • 4 CYL • 2WD
KATHY GAINEY
Stopped at light it shut off, lost compression and shut down and wouldn't start back. Didn't register hot it was normal.
Jul 14, 2020 at 5:06 AM
Good morning,
I would start with a compression test to verify the timing belt did not fail. You can rent a tester at a parts store. I would look for 13-150 for compression.
https://www.2carpros.com/articles/engine-stalls
I would also check the fuel pressure to be sure the fuel pump did not fail. You can get a tester at a parts store for this test.
Jul 14, 2020 at 5:43 AM
