Stability traction control light was on?
2007 CHEVROLET TAHOE
180,000 MILES • V8 • 4WD • AUTOMATIC
BECBIRD24
Stability traction control light was on, it went out and service engine light started flashing. when i start and stop it shifts hard like slipping and has a ticking noise.
Oct 17, 2022 at 7:04 AM
These might be two different problems but let's fix the warning light to see if that fixes the problem. The traction control light usually comes on when there is a wheel bearing hub going out because the wheel speed sensor is built into it. It is probably one of the front hubs. here is a video that shows how to change them out but to be sure let's run the codes (CAN SCAN) to see what comes up. You can get a CAN scanner (Controller Area Network) from Amazon for about $36.00.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Amazon CAN scanner link for about $35.00:
https://amzn.to/3R9lJ60
Here is a guide and video that show how to do the bearing hubs just in case you need it:
https://www.2carpros.com/articles/bearing-hub-replacement
and
https://youtu.be/ZgiPRG6jffc
Please go over these guides and report back.
Oct 17, 2022 at 10:30 AM
