Is it only the stability control light that is coming on? If that is the case, there could be an issue in the steering column. That is a theory at this point. Does anything happen if you turn off the stability/traction control?
What I am going to recommend is to have the can-bus scanned for codes. I'm suggesting that because there are a few different things that could be causing the issue and if we start replacing parts, it can be expensive and not fix the issue.
CAN stands for controller area network. Basically, all the different modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them.
Here is a link that explains how it is done:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Keep in mind, this could be something as simple as a wheel speed sensor that is failing. The traction control, stability, and ABS are all tied together. That is why we should scan it first.
Let me know if you have this done and what codes are found.
Jan 26, 2023 at 2:44 PM
