SRS light has turned on on driver's dash board
2014 VOLKSWAGEN JETTA
68,000 MILES • 1.8L • 4 CYL • TURBO • 2WD • AUTOMATIC
DRCORTES
I just came from watching your video on YouTube (https://youtu.be/gnSGfEqrf_w) for clearing the airbag trouble code. Unfortunately the OBD scanner you recommend is no longer available on Amazon. Is there another scanner you could recommend that I can use to clear the airbag trouble code on my car listed above? In case it's relevant, the light came on shortly after I installed a new stereo in the car. While doing that I made the mistake of disconnecting the passenger passenger airbag indicator light.
Jul 11, 2019 at 10:16 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Since you don't have access to a scanner/code reader you might want to consider 2 options. Most auto parts stores like AutoZone will check codes for free (have them erase) or you can disconnect your car battery for 15 minutes and then reconnect.
Hope this helps and thanks for using 2CarPros.
Danny-
Jul 11, 2019 at 4:02 PM
