Welcome to 2CarPros.
There are several things that can cause the light to stay on. However, without using a scanner, you can access diagnostic mode to see if there are diagnostic trouble codes that will tell us the problem.
Here are the directions. You need to follow them exactly for it to work. Please keep in mind, there are some problems that will not show up using this technique. However, most will. Try this and let me know what you find.
DIAGNOSIS SYSTEM (AIR BAG)
Trouble Diagnosis without CONSULT
DIAGNOSIS MODE
NOTE:
Diagnosis Mode can not be entered if a malfunction is not detected in User Mode.
1.Turn ignition switch ON.
2.After AIR BAG warning lamp lights for 7 seconds, turn ignition switch OFF within 1 second.
3.Wait more than 3 seconds.
4.Repeat steps 1 to 3 two more times (3 times total).
5.Turn ignition switch ON.
SRS is now in Diagnosis Mode. See: A L L Diagnostic Trouble Codes ( DTC ) > Manufacturer Code Charts > Flash Code Index.
Let me know what you find.
Apr 5, 2019 at 7:08 PM
