SRS airbag controller
1995 SAAB 9000
200,000 MILES • 2.3L • 4 CYL • FWD • AUTOMATIC
NTP
  • 22 POSTS
The exist SRS controller has intermittent fault the mechanics said it has to be replaced.
I would like to ask that If I replace with a good one, do I have to use scanner such as Tech II to remove the fault code from the old bad set or no need to do that?
Thank you very much.
Mar 10, 2016 at 10:29 AM
WRENCHTECH
  • 20,761 POSTS
You can't just slap a used module in there. They are programmed to the vehicle.
Mar 10, 2016 at 11:10 AM
NTP
  • 22 POSTS
The other words is the new one has to adjusted/provided for the car by tool like Tech II, right?
Mar 10, 2016 at 8:57 PM
WRENCHTECH
  • 20,761 POSTS
I don't believe the Tech 2 is capable of doing that.
Mar 11, 2016 at 1:57 AM
NTP
  • 22 POSTS
Then, what should I do for this case. Please advice, Thank you in advance.
Mar 11, 2016 at 2:38 AM
WRENCHTECH
  • 20,761 POSTS
You purchase a brand new module. New ones sometimes don't require programming. You need to ask your dealer.
Mar 11, 2016 at 2:50 AM
NTP
  • 22 POSTS
Mar 11, 2016 at 8:51 AM
