SRS off light on while driving
2016 TOYOTA RAV4
32,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
EIKSO
I notice that the airbag off light on the upper dash, center stays on while driving. Is this a problem?
Sep 21, 2019 at 2:16 AM
BMDOUBLE
  • 1,139 POSTS
If it is lit up for "off" this could mean that either there is something in the passenger seat that is similar to the weight of a small child, the passenger seat cushion sensor is faulty, the system needs to be recalibrated, or there is a fault of some other kind with the system. Other than ensuring that the passenger seat is clear, all other testing will need to be done with a scan tool that has the capability to read codes, parameters, and recalibrate the zero point setting.
Sep 21, 2019 at 6:27 AM
EIKSO
I forgot to mention that the seat is unoccupied with the exception for a couple of items placed there weighting no more than 6 ounces. Also, under the seat is an audio amplifier mounted to the floor - could that be causing a conflict with the SRS?
Sep 22, 2019 at 2:45 AM
BMDOUBLE
  • 1,139 POSTS
Only if it is contacting something under there or the wiring is tampered with.
Sep 23, 2019 at 9:05 AM
