The same tests apply, but you should start a new question specific to your vehicle. Unlike on other sites where anyone can chime in to confuse the issue, this was a private conversation between just two people. We're the only two who get an automated e-mail letting us know another reply was added. As such, none of the other experts are going to see your addition or have a chance to reply. That may not get you the help you need. Also, these are categorized in multiple ways to make them easier for others to find who are researching similar problems. By adding to this question, any solutions won't be found under your model or year.
Here's the link to start a new question of your own:
Please be sure to list the engine size, mileage, and transmission type. We look at the age and mileage when making generalizations as to best suspects, and we need to know the engine size and two or four-wheel-drive when finding the correct diagrams and drawings. That saves us time asking for those details, and makes finding the solution faster.
Loosen the belt, then try to spin each pulley by hand. One should be locked up or hard to turn. A less-common cause of this problem is when the drive pulley is cast as part of the outer ring on the vibration damper. Those are usually two pieces glued together with a thin layer of rubber. If that rubber breaks free, the outer ring can slip on the center hub. That will cause smoke and squealing.
Feb 16, 2021 at 7:42 PM
