Squeal all the time
2002 DODGE RAM
241,000 MILES • 4.7L • V8 • 4WD • MANUAL
WILLIAM S. LLOYD III
I was driving home from work and randomly the truck starting squealing when I pressed in the clutch. But while I'm driving it's fine. The thing I don't understand is it will squeal the same way sitting still with the clutch fully depressed. What the is the issue?
Feb 24, 2019 at 5:49 AM
SCGRANTURISMO
  • 4,897 POSTS
This is usually caused by a failing throw out bearing. This bearing is designed to press against the pressure plate and engage the clutch. I have included a link to a helpful guide for you to go to below.
https://www.2carpros.com/articles/clutch-symptoms
Then I have included in the diagrams below, step by step instructions on how to remove and install a new throw out bearing.
Thanks,
Alex
2CarPros
Feb 24, 2019 at 7:29 AM
If I can add, here is a video to show you step by step how the job is done on a similar car the process is the same:
https://youtu.be/JpzefqEeVGE
Please let us know how it goes.
Feb 24, 2019 at 11:27 AM
