Usually a squeal is going to be something to do with your serpentine belt. Check your serpentine belt and all the pulleys that the belt is running with your vehicle running. Have a helper rev the engine up, if needed to get the squeal to happen. If it is coming from the belt itself, you can get belt dressing from your local auto parts store for around $5.00 to $10.00. If it is a pulley, then the bearing is going bad and it will need to be replaced. I have included a link for you to go to below:
https://www.2carpros.com/articles/car-squeaking-noise
Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Apr 26, 2019 at 11:35 AM
