Squeal noise coming from under the hood
2008 DODGE NITRO
148,000 MILES • 3.7L • 4 CYL • 2WD
HENRY BREITSCHOPF
It gets worse when the clutch is engaged (standard transmission).
Apr 22, 2019 at 2:03 PM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with the throw out bearing. This is the bearing that sits of the clutch fork and is used to engage and disengage the clutch disc to the flywheel via the pressure plate. This bearing, when not properly lubricated will make a squealing noise from the transmission area. I have included a link down below for you to go to.
https://www.2carpros.com/articles/throw-out-bearing-replacement
Please go through this guide and get back to us with what you are able to find out, please.
Thanks,
Alex
2CarPros
Apr 23, 2019 at 1:11 AM
