Squeaking noise when accelerating
2011 FORD CROWN VICTORIA
200,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
KENT84
  • 8 POSTS
I have replaced the serpentine belt, the tension pulley, idler pulley, and checked all the other pulley's (good). Trying to see what else could be squeaking when I accelerate up to 2,000 RPMs or more. The transmission maybe?
Jun 24, 2019 at 10:48 AM
Good afternoon,
Does it sound like a power steering noise?
Can you upload a video of the noise so I can hear it?
Jun 24, 2019 at 12:58 PM
KENT84
  • 8 POSTS
No, it sounds like a belt squeaking. Sending a video now.
Jun 24, 2019 at 1:11 PM
KENT84
  • 8 POSTS
Did you see the video? Thanks
Jun 24, 2019 at 1:15 PM
Okay, got it.
I would remove the belt and spin the pulleys for the alternator, power steering pump and water pump and see if they make any noise.
It sounds like a water pump bearing. Check the idler pulleys as well that I circled.
Jun 24, 2019 at 1:20 PM
KENT84
  • 8 POSTS
Thanks so much for your expertise. I spun all the pulleys Friday and only one was squeaking (the tension pulley). I replace the tension pulley idle pulley and the belt. But I will do it again.
Jun 24, 2019 at 1:24 PM
Check that water pump.
Jun 24, 2019 at 1:26 PM
KENT84
  • 8 POSTS
What's a good way to check it? Spin it very hard? Thanks again I greatly appreciate it.
Jun 24, 2019 at 1:28 PM
Spin it with your hand. Check for any play as well in the bearing.
Does not have to hard at all.
Jun 24, 2019 at 1:32 PM
KENT84
  • 8 POSTS
Okay thanks. you made my day. have a great day Roy.
Jun 24, 2019 at 1:34 PM
You are welcome.
Always glad to help.
Jun 24, 2019 at 1:47 PM
