squeaking noise on the driver side
2011 NISSAN ALTIMA
72,000 MILES • 2.5L • AUTOMATIC
LILMAN40
Hi,my name is tommy i have a 2011 nissan alitma .When i slow down or step on the brakes i hear a squeaking noise on the driver side . i took off the wheel and the brakes to see if it needs new brakes ,the brakes and rotors is good. i check the right side also there ok. Do you think that the wheel bearing needs to be grease or replace.Theres no light indicator on.
Jan 5, 2016 at 10:32 PM
CAR-MAN145
  • 321 POSTS
It just mite be in the brake pad. If it only happens when braking then I would think its in the brakes only. Even know the brakes are good replace the pads if you want the squeaking go away.
Jan 6, 2016 at 12:06 AM
