Sputters, surges and lagging on accelerating
1993 OLDSMOBILE 98
120,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
JUSTINDRAKEC
My car sputters horribly when starting off from a complete stop or if I even give it good gas, especially at mid throttle. I’ve changed fuel pump, fuel filter, TPS, spark plugs/wires. I checked coils and they’re fine. I’ve used seafoam a few times over the past few months, didn’t notice any changes. Help!
Jan 7, 2020 at 9:50 PM
Good morning,
Is the check engine light on?
Did you check the compression?
I would not assume the coils are good. They are common failures for this issue since they are part of the module.
Fuel injectors could also cause this issue.
Jan 8, 2020 at 7:53 AM
