Spits and sputters when coming to a stop or when in park and idling
2005 CHEVROLET TRAILBLAZER
153,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
REBEKAH SHELAINE
I have the vehicle listed above. it runs fine until I come to a stop or if it is parked and idling; it starts to spit and sputter like it's going to stall. What do I do?
Nov 7, 2019 at 2:43 PM
Hi:
Is the check engine light staying on when the engine is running? I ask because many things can cause this type of issue. A dirty air filter, engine vacuum leak, low or high fuel pressure, and other things.
Here are links that explain how to test for a vacuum leak and fuel pressure. However, if the check engine light stays on, have the computer scanned. Most parts stores will do it for free.
_______________________________________________________
Again, if the light stays on, have it scanned and let me know what codes are pulled.
Nov 8, 2019 at 6:50 PM
REBEKAH SHELAINE
Thank you. I will most definitely take your advice. When I first start the vehicle the check engine light does come on but it does not stay on. I started my truck today and it wasn't sputtering. It was raining yesterday which might indicate that it could be a vacuum leak, but I'm not sure I will look at the links that you provided, again thank you.
Nov 8, 2019 at 7:00 PM
Hi:
If it seems to be associated with damp conditions, then I suspect an electrical issue. However, lets start with what I suggested and go from there.
Let me know the results.
Take care and try to have a good weekend.
Nov 8, 2019 at 7:13 PM
