My vehicle listed above ZJ has recently started running rough at times like a miss or trash in a fuel line. When I first start it, it idles a little rough then clears up but comes back sporadically. When it's rough it has a hesitation and the occasional miss but when it's smooth it's great no problem no hesitation nothing just smooth as silk. I pulled plugs and just normal wear. Same with distributor cap and rotor button. I cleaned everything, no change. I ordered fuel pump but was sent the wrong one, so I replaced the fuel filter on old pump and put it back in. Now it's running really good with the exception of the sporadic hiccup. Starts good idles good most of the time but still runs a little rough at times. I don't know what to do next. Can't afford a mechanic. I removed and cleaned the idle control module which helped a little. Any suggestions? My check engine came on but came back no data then went out and is still out.
Oct 5, 2022 at 12:01 PM
