Check rear wing stuck open when driving after erasing the fault system works properly until fault appears again and stops working and warning appears. Fault code 03132 limit switches, by using ohm meter I check the limit switches at close position and open position they are working properly what can be the problem? Rear spoiler control unit, and where is its location on the car.
Thank you
Thank you
Mar 18, 2022 at 11:57 AM
