My VSS is reading 9.4v on the pulse wire, 12.44v on center wire, .02v on ground.
I get the 9.4v reading at the ecu, gauge cluster, and VSS itself. No blown fuses. it is a chipped p28, 94 integra GSR B18C1
Any information would be helpful as I have read what seems like a book of threads from different forums and no one has had this issue...
I've used 2 different clusters, 2 different VSS.
Cleaned all grounds and in some cases moved to new locations. TPS reads fine.
also no check engine light.
Parts list if needed..
Header to APEXi muffler (2 1/2in)
CAI
SKUNK2 ALPHA RAD
SKUNK2 PRO SERIES 74mm tb & im
AEM high flow fuel rail
AEM fpr
Walboro 255 high pressure fuel pump
Chipped and dyno tuned obd1 ecu
Rywire b series tuck harness
Mishimoto 68°C thermostat
Almost every sensor has been replaced in the past few months.
Thanks in advance.
CAI
SKUNK2 ALPHA RAD
AEM fpr
Thanks in advance.
Sep 2, 2019 at 3:24 PM
