The speed pointer hand is facing straight down and stays the same while the car is going forward. I am told the entire instrument panel, or something needs a costly replacement.
Is it possible to use the speedometer sensor wires with a different speed gauge installed on the dashboard in order to save on the expense?
Alternately might a replacement part called "Universal X27 168 stepper motor instrument cluster repair speedometer" provide a fix without having to replace the entire panel? This item is said by Amazon to fit this specific vehicle, but I'm not certain if it would actually make the speedometer work again.
Jan 4, 2025 at 11:13 PM
