Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
F-150
Interior
Instrument Cluster
Gauges
Odometer
Not Working
Speedometer and odometer quit working
1994 FORD F-150
175,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
MENKE
MEMBER
FOLLOW
While driving smelled something burning saw no smoke. stopped truck could not see anything. when restarted speedometer and odometer not working.
Feb 18, 2019 at 9:48 AM
CERTIFIED EXPERT
Good afternoon,
Does anything else not function?
Does the transmission work correctly?
The sensor has no voltage to it. It generates a voltage to the ECM.
Feb 18, 2019 at 10:28 AM
MENKE
MEMBER
Everything else was working fine.
Feb 18, 2019 at 10:30 AM
CERTIFIED EXPERT
Okay, good chance the dash cluster itself has failed internally.
To confirm, I would have someone with a scan tool see if they can monitor the speed on there scan tool.
If they can, the cluster is bad.
If they cannot, it sounds like a wiring harness issue.
Feb 18, 2019 at 10:40 AM
MENKE
MEMBER
Thanks, I'll get it checked out.
Feb 18, 2019 at 10:41 AM
CERTIFIED EXPERT
Sounds like a plan.
Feb 18, 2019 at 10:43 AM
