Vehicle listed above is the limited model. Sometimes when driving the speedometer drops to zero for a few seconds and all warning lights come on dash (check hybrid system, check brake system and check 4wd system). If you turn engine off and back on, only check hybrid system will stay on. If you check with an OBDII code reader, there are no error codes. If you clear codes with OBDII code reader, the check hybrid system message will go away. This has happened multiple times. Sometimes after driving 500 miles, sometimes after only 1 mile. Took to Toyota dealer and they cannot find anything wrong. Replaced; battery, checked battery cables, checked all fuses and checked electrical plugs that i could find. Nothing wrong, but i have to keep erasing error messages that are not real. About to lose my mind…
Jan 22, 2021 at 2:20 PM
