After installing a new speedometer cable and bolting it, I over torqued the 10 mm bolt, and it snapped. The bolt broke off below the cable bracket hole (as if the cable is no longer held down by the bolt but the transmission has all the remaining threrads). Can the speedometer cable come loose on its own while the vehicle is in motion, and what happens if that happened? Is an extractor going to do the job to replace the bolt? I can hardly reach that area. What do you recommend? Thanks
Jan 27, 2021 at 2:43 AM
