in hot weather speedometer stops off and on?
1995 DODGE CARAVAN
125,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
MOEFREITAS
When vehicle heats up in hot weather speedometer stops off and on. Winter have no problem. What is it ?
May 24, 2017 at 6:21 PM
Here is a guide that can get us started on the right foot. It sounds like the VSS is going out or the instrument cluster
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Please run some tests and get back to us so we can continue helping you.
May 27, 2017 at 12:52 PM
MOEFREITAS
What I mean by heating up is the air temp. When it's 70 or above weather air temp it starts to act up. In the cold air everything is fine. I feel between air temp and vehicle operating temp is over heating what ever is the cause. Winter months never acts up. What I mean by acting up is : Speedometer starts to go up & down then goes to zero when at zero get a lag in performance and the engine lite comes on. Shut vehicle off it cools down everything goes back to normal engine lite is off runs great until it heats up again. Thank you for your time and help.
May 29, 2017 at 11:47 AM
Okay that makes sense, lets run the codes to see if there is a temperature sensor that is acting up.
Please let us know what you find.
May 29, 2017 at 12:24 PM
